I am an Orange User. To check my phone bill status, I need to send an SMS to a short number-416.
I use to send blanks from phone side, but each time when I must type the 416 number I found that 9210 puts a phone number by default:97255369864.
I need to clear this This means 11 times pressing clear button, an then type my 416 number.
How can this be solved?
Cheers
Maybe you have a default recipient number for SMS.
Ce zici???
I don`t think it is this one...How do I check it out?
Sigur.. 😉
I don't think that you can change it from your phone. Try another model,like 7110,which i used to have. It has this feature! To see if the default sender number is activated, just watch the number which is showing, everytime you want to send an sms. Is it the same number?
Yes, always the same number...
Even if I change the SIM card...
Hehe, you don't need to press Clear 11 times - just press and hold it for a sec or two.
Long-time known Nokia feature ;-P
Format and you'll get the number cleared away...!?
Nope, it does not help...The format ...
Use another mobile phone. The11digit number has been stored in your sim card. Put your sim card into another mobile phone,like 6110 or 7110 and find the sms settings. Replace the 11digit number with blank. If you don't have mobile go to a nokia center to help you.
Yeah,
This was the problem.....
Now it is ok.
10X
