Hello guys!
Thank you so much for posting your coolest and brightest backgrounds. I now ask you to post your BEST, BRIGHTEST, and COOLEST operator logos whether colored, grayscale or black & white.
:fadein:
Hello guys!
:fadein:
I got the Symbian logo from, http://www.symbian.com.
Thank you for posting 8)
umm, how to put the operator logo in the phone? and what format (size, color, file type etc)?
An operator logo is a 95 by 25 pixel bitmap.
You can set it manually with a file manager tool (such as FExplorer) in the directory "c:\system\Apps\phone\oplogo" (create the directories in the path, if they don't exist) with your operator's network number.
Use, e.g., http://www.bryte.net/network/index.asp to find yours. Searching there for operators in Albania yields, for example, Vodafone Albania and states that the code is 276-02 (first part is country code, second part is network code), which results in that the operator logo file name should be "276_2_0.bmp" (drop leading zeros from the codes, use underline to separate the codes and finish the name with "_0.bmp"😉.
Or, if you don't care how it is done, you can simply use programs like FExplorer, ActiveToday, etc., that have built-in features to set an operator logo from the currently used operator from an image file you point them to. 😉
And, of course, to delete the operator logo, just delete the file(s) in the above directory.
Check this out
[quote="N/A"]You can set it manually with a file manager tool (such as FExplorer) in the directory "c:\system\Apps\phone\oplogo" (create the directories in the path, if they don't exist) with your operator's network number.
Use, e.g., http://www.bryte.net/network/index.asp to find yours.[/quote]
If you got FExplorer, you can see it from there, just go Network --> Info (MCC and MNC).
My contribution
Mine! 8)
I don't know how to create my own operator logo. can anyone make me a nice "girosky" operator logo. i would really appreciate it!!! thanks people!!! 😃
here's mine...
for all of you with the same name 😉
here's mine...
[quote="eone"]umm, how to put the operator logo in the phone? and what format (size, color, file type etc)?[/quote]
you can use system tools to set a operator logo its easyer cause you don't have to search the file
Or you can get FExplorer from www.gosymbian.com which is a freeware file explorer that has a Custom Operator Logo feature.
this is my operator logohttp://www34.brinkster.com/spaubeekcity/scr.jpg
hey lunimax
dem logos are tight.. but why nokia ?? that finding nemo thing is great.. i like it..
cool lunimax 😃 man can you make me one plsss The Party Boy, it's up to you how will you do it, thanks a lot. 😊
The Party Boy
@Luminax:
These op logos are great. Luminax u sure have an amazing talent for this. Can you design a few for my name as well - "Ali Asghar".
Thanks in advance
hey luminax how about mine "girosky"? thanks man!!! nice op logos! 😃
thanks a lot lunimax 😃
thanks a lot man!!! you really do have a talent for this. how do you do it? a trade secret? 😃
Luminax you've created amazing operator logos. How about making me one. Mke it DEDBOL and the other is BLACK HOWLING.
Thanks in advance!!! I'll be waiting
Wow these r cooooool! just got my 3650 and just browsing and i found this forumn , nice work ppl , can someone make me a logo that says 'fewzz' please
thanks
@luminax:
Thanks buddy... the logo is pretty cool!! but only 1 for me 😞
