Hi, 😃
I use the SMS function for my day-to-day business activities as well, so I feel that there is a real need to print the SMS messages in hard copies.
What would be the best way to transfer the messages to my PC and get them printed in a organised manner?
Any suggestions will be welcome!
try using SMS Journal (a PC program) -- i think it's a freeware, maybe it will help you print easily your SMS.
Or try get a printer with an IR port (eg. HP Laserjet 5p - what I use - very handy).
For Whiplash:
SMS Journal huh? Interesting. But how do I transfer the SMS from 9210 to the PC in the 1st place?
I can synchronise my 9210 with PIM programs, but no similar function for SMS i guess.
hi, below is an excerpt of the SMS_journal text file:
"The program runs on a PC running Windows. You will need a mouse. Do not try to use it on your Communicator.
The purpose is to import SMS messages from a Communicator file/folder copy on your PC, to display them and to export the messages.
After unzipping the file, copy the contents of the archive into a directory of your choice, but keep all the files together."
- to answer you question - yes, just link your 9210 to your PC via cable or IR, and you can import sms from your 9210 to your desktop. now, you can easily print your sms! 😊
whiplash wrote:hi, below is an excerpt of the SMS_journal text file:"The program runs on a PC running Windows. You will need a mouse. Do not try to use it on your Communicator.
hi whiplash,
you've mentioned handset model 9210, what about for 7610, what program can i use to be abe to print my SMS messages fr my Nokia 7610 inbox?
Thanks...
Please reply on [email][email protected][/email]
Augustine Barb wrote:I have a blackberry pearl and Ive been getting threatening sms text messages lately that I need to print out so I can take them to court I allready got the data transfer cable and have the files on my computer the format starts with .i (i believe and has like 4 letters) is there anyway I can get a converter or something to make these so I can print them out???
I was surprised when I came upon your post. How unaware am I of the laws now when I did not even know that SMS messages are already admissible to court! have read once that since the telecommunication companies keep tab on our correspondence, only when the court asks them to will they be able to release their record of our communication movements.
