How do I restore my Vodafone Operator Logo?????
2 replies · 1,855 views · Started 15 July 2003
Hello all, ive got system tools version 1.31 by PsiNT. I have changed my operator logo to a picture but it comes out really small and crap. Does anyone know how i restore my original one? There is an option to restore to factory settings but i'm a bit dubious about selecting this option.
dont know about recovering the oplogo of vodafone, but the oplogo must measure 97x25 pixels - if not it gets rescaled (which sounds like what has happened to you).
So either you send the file to your PC and resize it with an image editor, or you could also find some oplogos already correctly sized (do a search in google)
I think I read here that you simply delete the oplogo file from the phone and reboot.
The network one will then show - not sure thou, I've never deleted my custom oplogo?
Worth a try..
Will
