why isnt there a preogram that.......
5 replies · 1,606 views · Started 15 July 2003
why isnt there a preogram that makes someone's portrait photo come up full-screen when they ring? - like the p800!
There was one in developement but it seems that the author is lacking stamina these days 😃
I'm not pointing fingers or anything 😮ops:
[quote="GrammatonCleric"]There was one in developement but it seems that the author is lacking stamina these days 😃
I'm not pointing fingers or anything 😮ops:[/quote]
Any link, author's webpage, blog or something??
there is one.
Do you want to see more cool details of the persons who are calling you? Well, use the "Full Screen Caller" and your wishes will be satisfied! Full Screen Caller allows to see a big picture of persons and skins when you are receiving a phone call of persons you have stored in your database!
Skins view:
This is the main view of the Full Screen Call. In this view you can find the following commands:
* Turn On/Off;
* Select skin;
* Create new skin;
* Edit skin;
* Remove skin (hot key: � );
* Send via Infrared, Bluetooth, EMail;
* Check inbox for the new skins (this operation is also executed with the start of the Skin Editor).
To turn the Full Screen Call you need to have at least one that would be selected.
Skin edit view:
In this view you can use the following skin properties:
* File name - this is a read only property where the whole skin path is saved;
* Info - in this property the name of the skin is stored, that can be seen in the "Skins view";
* Background image - this property has two values:
o Gradient - when this option is chosen it is necessary to set the BG Start colour and BG End colour properties;
o Image - any picture that will be used in the the pop-up window that appears during the call, preferable image size 176 x 187;
* BG Start colour - start colour for the background gradient bitmap;
* BG End colour - end colour for the background gradient bitmap;
* Font colour - foreground font colour;
* BG Font colour - background font colour;
* Font name;
* Font size.
The size for the image and text:
* Picture - Top X = 30, Top Y = 2, Width = 115, Height = 138;
* Phone number - Top X = 4, Top Y = 143, Width = 169, Height = 19;
* Caller name - Top X = 4, Top Y = 166, Width = 169, Height = 19;
BROUGHT TO YOU SOON BY SYMBIANWARE !!!
Until i see a confirmation from Hera,or anyone of the established SymbianWare members,for me,this is just another vapourware thread.
