I've downloaded an Mp3 player app today, anyone else tried it? I take it the use of a handsfree headset is going to give better sound quality than the 3650 speaker? As soon as i upgrade my MMC i'll download some tunes and give it a try. :-}
Mp3 on 3650
What is the Apps name or the site where you downloaded it? That way I can check it out 😊
I think this was it...
www.no.warez.com
-GhostDog edit-
Warez is not alowed on AAS.Infinityx,consider this a warning,if you continue breaking forum rules your ip will be banned.
It works. But 3650 loudspeaker isn't all that loud.!?!
[quote="Infinityx"]I've downloaded an Mp3 player app today, anyone else tried it? I take it the use of a handsfree headset is going to give better sound quality than the 3650 speaker? As soon as i upgrade my MMC i'll download some tunes and give it a try. :-}[/quote] if you will use headset,the quality will be better,but no at all.its mono. :-?
GHOSTDOG, apologies, i'll have to be more careful in future. =-(
