flip closed, press menu button, press #application you have
1 Mobile Camera
2 Messages
3 Contacts
4 Calendar
5 Tasks
6 Jotter
7 Voice Memo
8 Onlien Services
9 Connections
10
I tried the Flip Closed Shortcut in Control Panel, that only changes the five shortcut on the screen, not this standby view menu.
Any clues?
i only came across this app list when i put the flip on yesterday for cheap giggles, my last one is "unreal player" though
You can't change that menu. The applications you see is only the applications that support flip closed mode. If you install a new application with support for flip closed mode it will automatically be added to the menu. If it does have support it wont show up in the menu. It's that simple.
/t
