I don't now what to do: i have nokia 9210, dutch version
when i installed "all nokia", the software "clock" will show up in de menu "extra", but when i puch on it, de communicator say: "niet gevonden" (not find), i have try to installed again & again & again... it don't will work, only the first time when i have bay the nokia, he was working, i don't now what i do wrong, please help me...because i need this software when i make trips to other countrys, please email me if you can help me: [email protected]
Problem with the clock
here you go...
NIKI, did this solved your problem?
I don't now what you mean with it.... so i have still the same problem
TheSpecialBoy heeft een bijlage bijgevoegd met het aparte installatie bestand voor de clock applicatie.
Maar om deze te kunnen zien (bijlage) en te downloaden moet je geregistreerd zijn.
Dus ff registreren, en installeren.
Because he is a guest he has no idea that you included the sis file 😉
Register dear Houben Niki, register... 8)
Nope, i have instaled the file "clock", but still the same problem...
Then I think a backup of your data and a format shall help you solve this issue....
Format always work. 😉
What RAE are you using?
What is RAE?
how can i format? is there some program or code to do a format like whit PC? (format c:\)
if i do format, must i take first all my contacts to the PC or is it only the installed programs deleting?
Sorry, i don't have many expirence whit the nokia 9210, i only have it about 2 weeks now, before this i have used 9110.
Already my great thanks to everybody of this forum for the helping.
OK, Niki,
Let`s do it neat and clean.
First of all, suposing that you have a PC Conection, you need to backup all your valuable data(documents, databases, contacts, and so on)
You can back them up on PC or MMC using file explorer feature.
After that, make shure you have on MMC or PC(if you have a cable or IR connection with 9210) the all nokia sis files.
If you do not, you can find them on www.nokia.com
To format your 9210 you need to restart your 9210 by removing the battery.
Put back the battery and when the startup logo appear, press Ctrl+Shift+F
If you confirm yes, all the data from your 9210 will be erased...
Check also
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=10902&highlight=formatting
If you need more help, let us know.
BUT FIRST DO A BACKUP OF YOUR CONTACTS AND DOCUMENTS!!!!!!
ChivasBoy 😮ops: SpecialBoy 😉
Okey, i have made format C, np
but there or still many programs on my D:
How can i erase this?
Ok, it works, i have made format C & D (with the 9110)
My great thanks to everyone ho helps me.
Niki
File manager,menu and search the option format mmc 😉
I don't think you will have to format d: drive (MMC).
Try now to install the software again ( I supose you now how to do that, you allready sayed you did) and tell us the results. good luck.
[quote="Dazler"]TheSpecialBoy heeft een bijlage bijgevoegd met het aparte installatie bestand voor de clock applicatie.
Because he is a guest he has no idea that you included the sis file 😉[/quote]
Whoa! u also speak DUTCH? Cool! 😉
