The direct access Ctrl-l is used in Word (italic) or RingMaster (insert note) for example.
My problem is that when I have installed TaskManager (v1.33F), the direct access Ctrl-l doesn�t work. And when I uninstall TaskM then Crtl-l works.
Does anybody know about this?
Regards
I'm using Task Manager without any problems, could it be that Ctrl+I has been assigned to a shortcut keys?
Arild
<TABLE BORDER=0 ALIGN=CENTER WIDTH=85%><TR><TD><font size=-1>Quote</font><HR></TD></TR><TR><TD><FONT SIZE=-1><BLOCKQUOTE>
On 2001-10-29 2130, Manowar wrote
Regards
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR></TD></TR></TABLE>
No,no.. I have not assigned Ctrl-l to a shortcut key.
I don�t know why.. Perhaps it can be a conflict between apps.
Thank you anyway.
Regards.
Well, to be sure about my problem with Ctrl-l, I have just formated totally the device (9210 and MMC) and after that I have reinstalled All Memory Data.sis and All Memory Card Data.sis.
Then I opened Word and tested the direct access Ctrl-l. It works Ok.
All was Ok.
And after all I installed Task Manager.
I opened Word again....and Ctrl-l didn�t work....
I don�t know why...
Any idea?
Regards.
