Is there a way to record videos longer then 10 seconds? like record as much as you want till you hit stop or when yoru memory is out or something???
Is There A Way To Record Longer Videos?
Yes there is.
Try searching mate 😊
Ha Ha!! Now i see what you mean Willbrady... It does get annoying after a while... ...I recently asked this question, so do a search for hipcam or ETI Camcorder. I'm now using ETI and can reccommend it.
i can recomend ETI cam rec too,its the best one cam.rec,the only disadvantage is in playing videos,when you play recorded video,the framarate is slow.. :-?
I'm not a fan of ETI personally. Sound and pic never seem to be in sync. 😞
