[quote="willbrady"]...my grass goes right up the the flower beds and against a log roll 'wall' so I assume it can not mow right to the edge - but how much of an uncut border will it give me?[/quote]
Walls are no problem, if the mower hits anything vertical and stable, it just backs up and turns. If you want to protect the wall from being bumbed into, use the cable. The Husqvarna (the tip of the mower I mean) continues about 30 centimeters over the boundary cable before it stops and turns, so the cable has to be placed accordingly. To protect flowers or anything you don't want it to bumb into, surround it with the cable. And yes, use the shears for the edges. There will be 15-20 cm borders of uncut grass.
[quote="willbrady"]...Do you think my lawn is too small (2 areas of about 11ft*8ft, told I was lazy!) [/quote]
The Husvarna is recommended for areas up to 1500 sqare meters, I don't what it is in square feet. It says in the manual it mows about 100 sqm per hour. If there are two areas there are things to consider when placing the cables. But you'd better refer to the company manual. Steep slopes are a problem too.
[quote="willbrady"]...Does it really go to it's house to recharge and come out again or do you find it gets lost and mindlessly roams the garden looking for it's 'home'. [/quote]
No, never. It always goes home to recharge. It has a cabeling for that, it uses a certain path every time. It recharges for about an hour and then it starts to mow again. It's amazing but it works 😃
[quote="willbrady"]...Was it easy to install? [/quote]
Some guys came and did it, it took couple of hours if I remember correctly. The cables can be moved later to a certain extent, it's no big deal. I guess you could do it by yourself too if you have the specs and a manual.
[quote="willbrady"]...Also my daughter always leaves her ball & toys on the lawn - will this cause a problem do you think? [/quote]
This might be a problem. I have now learned to put everything in it's right place, shoes, gloves, scissors, rakes etc lying around make bad noise when they get caught in the blades. But the Husqvarna has a timer, so you can set it to mow only during night time for instance or some other time when it's convenient.
My husband has never been happier! Now that he doesn't have a guilty conscionce about the unmowed lawn all the time, he actually likes to do things in the garden 😃
