Mobile fax
4 replies · 2,083 views · Started 17 July 2003
Does any one here encountered problem with Mobile fax application. I installed one here but it won't run. I already installed it in my phone memory as suggested by somebody. The error I got: mobile fax operation time out. Tried it several times but same error comes out.
I use it (I'm a register user) without problem, it works fine for me on a Nk7650.
Domi.
I don't think so because the operating system of the 7650 and 3650 is the same. But I use two numbers on my phone, one for the voice and the second for the fax - are you used 2 numbers too ? the mobile fax *MUST* run in background in order to hang-on automatically.
Domi.
I guess thats the reason why yours are working fine. You will have to login to your fax number before you run your mobilfax
