SOS: My Log is 30 minutes behind
4 replies · 2,288 views · Started 18 July 2003
Hi!
I have Nokia 3650 (Firmware Version 3.13). Can some Good Samaritan help me get rid of this irritating situation? All my logs (both of phone calls and SMS messages) are running 30 minutes behind the actual time? The clock is still showing the right time, but the log of all received, missed, outgoing calls and similar entries for SMS messages is 30 minutes behind. The only thing extra that I had done was to install Handy Clock and WorldClock Pro (though I am not quite sure whether this problem is linked to this only). I have even uninstalled these programmes. Still, the problem persists. PLEASE HELP.
Well, I searched for all the topics with Jesal as the author. Your first post is dated December 08, 2002. So may be that thread has been deleted. In any case, can you please tell me the solution??
well i started with fw 3.12 and there was no problems with it. its only after that u sync with ur computer it goes 30 mins back. tried every trick does not work. even u format the phone and dont sync it with the pc it goes normal. then even with 4.39 the same thing happ. after sync. no solutions just minus 30 mins u see of all calls or get the pc's time 30 mins back i guess that shud work 😃
Hi
I had the same problem.
My phone has firmware version 2.50
Well, I tried various things and I noticed that if you NEVER ENABLE automatic time update on your phone and sync it with your PC the time is shown correctly in the call register.
Even if you disble automatic time update the wrong time is displayed(exactly 30mins behind)
To resolve this you have to format your phone(*#7370# ; you need your lock code).
By default automatic time update is disabled. DON'T ENABLE IT.
Now even if you sync it with your PC the correct time will be displayed(if the phone clock is set correctly)
Hope this helps
BTW Jesal, Where in India are you from (near Delhi?)
Ashish Kumar
