ringtones don't seem to work :S
2 replies · 1,384 views · Started 18 July 2003
When I set my ringtone for example to b.mid, every time I get called I still hear the nokia tune.mid ringtone. Also none of the profiles have even the nokia tune.mid ringtone set as the ringtone to play when somebody calls you!
does anyone know how to fix this problem?
The B.mid must had been active on the recorder application where you listen to it.
You must exit out so that it will be avaliable when the phone rings. :P
