Whenever i record a video clip using eti, the sound is always slightly delayed by a second or 2 when i play the video. Help!
Eti camcorder troubles
Yeah, sometimes happens, ETIcamcorder uses two diferent files for each video, .eye for video and .ear for the sound. I think when the phone mix them to play the video it creates a delay...
But when I play that videos on PC they seem to be correct...
is there any other software that can convert the .ear and .eye files into one .avi or .mpeg?
The software eti provides just does not work for me - no matter what i do....its doing my head in!
yeah i hav it i tihk its called EYECON
Mmm I think the Eyecon is the program that provides Eti..
I didn't work for me, but after putting the files en the eyecon folder in c:\eyecon ( must be that ) and using the EyeconGUI I converted the videos 😉
If you have WinXP maybe you should activate "Compability with Windows 95/98" in program properties.
Good Luck 😉
Ps.: I think you cannot convert videos WITHOUT audio :-?
