Nokia 3650 questions?
4 replies · 6,407 views · Started 19 July 2003
I am a new owner of Nokia 3650 and I have some questions to check with Nokia 3650 owners out there so here are that:
-can somebody send me the original Nokia wallpaper (i.e. the one when you first turn on the power switch)?
-I recently uninstalled the opera browser for series 60 from my 3650 but I notice there are folders like �Nokia� and �Opera� in Menu>Image which I have to delect it manually, which is similar to Windows OS when uninstalling programs, can somebody please explain to me why this happen and any suggestions, thank.
I also notice that there is a �OPERA� folder in a pre-install program call PRINT KODAK (Menu>Print Kodak>Print my pictures>MMC card>System>Data>Opera )which I CAN�T delect it ! Any suggestions? And this bring me to the question of �Windows explorer� in Nokia 3650, how to access the files �inside� the Symbian 6.1 and Series 60 in my 3650? As you all notice that under PRINT KODAK there is a folder called SYSTEM which we can�t access from the �Normal� menu...please assist me on this.
-how you all clean out the body (especially the white part) of 3650 as I notice it tends to get dirty easily?
-has anyone successfully pair 3650 with SonyEricsson Bluetooth headset HBH-35?
The wallpaper should still be on your phone on drive Z:
Use FExplorer from http://www.gosymbian.com to find it (and also to delete the "leftover" Opera files).
i want to format my phone nokia 3650 because so error all the time ! and i need format then so same the new phone . how can i do can u tell me something and i need to do by my self
"dial" the code *#7370# where you'd dial a number
make sure battery is full or you have the phone on AC (you don't want to loose power in them middle of the process)
have your phone's lock code at hand (default is 12345, if you haven't changed it)
all your data (settings, messages, photos, contacts, etc.) will be gone if you do this.
the memory card will not be affected.
also, please learn to use the search feature on this site (it would've answered your question, too): http://www.allaboutsymbian.com/forum/search.php
Whre Do I Found Free Application For My Nokia 3650.... Plzz Reply Me Asap Thnkzz...
