i know there are high cap. batt. available but i was wondering we could use nokia only. i read on a lotta places that 7650 has 650 MAH batt. now is this right ? i think it is BLB-2. also i read in some places that the batt that comes in 6610 is 850 MAH, now is this right ? i have used the 6610 batt on the 7650 it is smaller than O.G. 7650 batt. but does that mean that it will last a lil longer than the 7650 batt.
Battery Power
heard that 3650 comes with a spare battery........ i bought it with no spare........ how about you jesal?
The 3650 battery is better thabn the 7650. The 7650's is the same as the 8310!!!
im fine thk u . wht bot u ? i dont think ne nokias come with spare batt.
only samsungs do i guess. deathmonger i am askin for the batts of 6610, i know that 8310 batt same as 7650.
I've been using a 1100mah battery (not Nokia) from www.solware.co.uk and I get maybe about 30% more usage than the std one.
yes, the 8310 battery is the same - you can also get a 1250mah batt from http://www.nixie.biz/
also, may have been mentioned before, but look at this... http://www.p800er.com/product.asp?id=101
Just bought a 1000mah batt.. non nokia
brand is Acson.. haven't really test the power of it
as this is only my 2nd re-charge.
