Not happy with AAS FORUMS
3 replies · 1,724 views · Started 20 July 2003
Sorry to say but i am not happy AAS FOURMS. The reason is that, i hv post a query regarding the 'LOW VOLUME OF NOKIA 7650 RING TONE' but still no reply! I hv edit the tone using ringtone studio, but no success.It works properly on recorder(loud enough) but when there is incomming call the ringtone is very low.But belive it or n't we can make the ring louder. Sometimes the ringtone is loud enough,it works properly till i restarts my phone.Sure there should be a way. I willbe very greatfull
Perhaps no one has answered your query because it has already been discussed at length and you should be doing a search before posting a new thread.
Or perhaps no one who knows the answer has read your post yet.
I certainly have not experienced this volume change?
Have you tried a seach to see if anyone else has experianced the same problem?
Sorry I can't help.
Will
i'm not happy with AAS either, they don't make it clear enough for people to search the forums first before posting,
if your having problems with your ringtone volume, try some common sense first, like set it on maximum volume, if you turn off your phone, then turn it on again and it's gone quite again, then it'll be a problem with your phone or an application is doing that,
[quote="Akshay"]Sorry to say but i am not happy AAS FOURMS. The reason is that, i hv post a query regarding the 'LOW VOLUME OF NOKIA 7650 RING TONE' but still no reply! I hv edit the tone using ringtone studio, but no success.It works properly on recorder(loud enough) but when there is incomming call the ringtone is very low.But belive it or n't we can make the ring louder. Sometimes the ringtone is loud enough,it works properly till i restarts my phone.Sure there should be a way. I willbe very greatfull[/quote]
last time i replied to ur question.......... yes, midi ringtones have low volumes......... even ringtone studio cant help.......... try to use wav instead of midi........ u find here lots of wav in ringtone thread......
