Sorry to say but i am not happy AAS FOURMS. The reason is that, i hv post a query regarding the 'LOW VOLUME OF NOKIA 7650 RING TONE' but still no reply! I hv edit the tone using ringtone studio, but no success.It works properly on recorder(loud enough) but when there is incomming call the ringtone is very low.But belive it or n't we can make the ring louder. Sometimes the ringtone is loud enough,it works properly till i restarts my phone.Sure there should be a way. I willbe very greatfull
Not happy with AAS FORUMS
Sounds to me like you have a profile set with a low volume.
I would suggest Personalising the General to the Max Volume Level. You then need to make sure that you have made that profile Active.
Or maybe an old firmware version.There was a bug with older firmware version,ringtones not being loud enough.I think TANKERx discovered a trick with the voice dial button that fixed it(temporarily).
[quote="GrammatonCleric"]Or maybe an old firmware version.There was a bug with older firmware version,ringtones not being loud enough.I think TANKERx discovered a trick with the voice dial button that fixed it(temporarily).[/quote]
which old version? want to change version, which is best?
The latest of course,v 4.46.The bug was in v 3.12 and v 3.16 i think.
