Still i could not make my Mobilefax work. Somebody says 2 install in my phone's memory but same thing happened..I got operation timeout error. Can anybody help?
MobileFax
I may be wrong but from the sounds of it I think your using a much frowned apon warez version of this app.
The full purchased version works 100% and if it will be of serious use to you I'd suggest buying it and rewarding the developers for their skill in writing the program.
I'm sure you'll get a few more posts like this saying the same, unless you have purchased it already. If this is the case make sure your service provider allows for data/fax calls as this needs to be invoked.
Ian
