Hissing sound from the charger port ??
7 replies · 2,919 views · Started 21 July 2003
guys
please try this
go to silent area without any sound at all. Then open up your communicator, after that put the charger port or where the headset port near ur ear
for me i hear somekind of hissing noise coming out from the port but if i close the comm the hissing noise is gone
what happened to my comm LOL
but the sound is very unhearable if u did not put it right near ur ear 😃 😃
is urs like this also ????
Not really. You can hear a very slight noise -an electrical almost inaudible buzz- but it should be normal, and not as loud as a palmpilot or Clie running on batteries. You should check with a nokia store in case something happens to yours...
ahhh.....
so this is kind of normal 😃
thanks guys 4 checking it out
btw why is the screen making that kind of noise ?!?!!
