Is there any software available that would let me compose SMS messeges on my PC, and send them via bluetooth though my Nokia 7650.??
Regards
Matt
Regards
Matt
Yeah sure there is.
Remote60. You can control every aspect of ur phone from your pc ( Inluding composing messages and sending them...if that's what you mean)
You will be writing messages on ur phone directly when u type on ur PC keyboard and also send the message from you phone with commands from ur from ur PC.
Good Luck
This is a little late, but this program is great, bought it right away after seeing what it could do.
Thanks for the tip Sanjay.
There is an other software, desktopmessage, faster but only for sms. Find it at handango.com !
[quote="Toxyturvy79"]Is there any software available that would let me compose SMS messeges on my PC, and send them via bluetooth though my Nokia 7650.??
Regards
Matt[/quote]
Like TheAfrodiziak said,desktop message does exactly that,fast and simple.
http://my-symbian.com/7650/applications/applications.php?fldAuto=563&faq=2
