9210 to 7650 transfer...
3 replies · 2,316 views · Started 27 July 2002
hi, this might have been asked before...
i would like to know on how can i transfer or copy my 9210's contacts, sms and calendar entries to 7650. is there a software? or just simply send files via IR. or should be via PC.
TIA. 😊
The best answer here is to IR the contacts over via the IrDA ports.
You could sync to Outlook and Sync back down, but you would loose a lot of information and formating. Although (strangely) syncing a short period of vital Calendar data is probably easiest using this methof.
Don't think SMS transfer can be done
[quote="whiplash"]hi, this might have been asked before...
TIA. 😊[/quote]
There's no software I know of...One way might be to sync with the 9210 and then with the 7650?
Rafe
thanks guys for the replies. hope there will be a software to help migrate essential data back 'n forth. i believe there are a lot of 9210 & 7650 owners at the same time. (maybe a poll on this stats?)
good day 😊
