SD Too? (from a soon to be 3650 owner/newbie)
3 replies · 1,458 views · Started 22 July 2003
I just ordered my 3650 and am anxiously awaiting its arrival. One thing I was wondering is, does it take both SD and MMC since they are the same form factor and I know alot of other devices will take both types (like my IPAQ and my digital camera)?
I already have several SD cards so I HOPE the answer is yes. But I have a feeling it's not going to work since no one ever mentions SD in this forum.
Thanks!
If you searched the forum, you would find that SD cards do NOT work with the Nokia 3650 phone.
Threads on other forums suggest it is a possibility, but realistically no it isn't. Apart from anything else, SD physically doesn't fit in the space. It is FRACTIONALLY thicker so to make it fit would involve a file. Not recommended you try that!
