What does "File is embeddable. Do you wish to continue&
2 replies · 1,208 views · Started 22 July 2003
hi guys, i encounter this while using stacker. what does this means?
i continued and nothin was wrong. file gets archeived. so what does this really mean??
thanks
[quote="Anonymous"]hi guys, i encounter this while using stacker. what does this means?
thanks[/quote]
It means that the file will be able to work as a normal app without you having to un-archive it first.
hmm.. but then again.. i dun find a difference in files that are embeddable and not embeddable. they all get un-compress when u open them and compress back automatically when u close the app...
