want help
3 replies · 1,167 views · Started 23 July 2003
please tell me how to connect nokia 7650 with pc.how should i install pc suite in my phone.i have infrared but then also it is not connecting,so please help me in details
(magic word = please 😃 )
I think the best starting place is the documentation which comes with pc suite. Then try searching the forum, there are 00's of threads on pc suite.
anyway, all you need to do after installing pc suite is activate the IR on your phone, you should then see an icon in your pc's system tray. you'll also have a new icon which is mrouter, you can see the status of the ir connection there.
if you still aren't connected, have a good look through previous threads on this forum
Paul
Word of advice, IrDa is always a bit of a b*tch to set up and run smoothly. Go out, and get urself a cheap USB Bluetooth adapter, (i reccoment the D-Link DBT-120) and install that. Far easier to set up/utilise. Never need to get line of sight etc!
hmm, I actually use IR, with a w2k server laptop, I've never had a problem (fortunately) - although I know a lot of you use BT, there are a lot of threads here about various BT driver/connectability issues!
(also, no need to buy more hardware 😃 )
