New: Pdf+ for the Series 60
1 replies · 2,221 views · Started 23 July 2003
Thanks to mBrainSoftware you can now read PDF files on your Series 60 device. The software enables you to not only open the files, but zoom in and out, follow bookmarks, view in full screen, search files and more. The first public version is a beta.
More from: http://www.mbrainsoftware.com/
With Pdf+ you can:
[list][*]display all the PDF files you have stored on your device.
[*]display the text, line drawings and images on a PDF file.
[*]view and follow bookmarks.
[*]zoom in and out to maximize the amount of text and graphics you can read on the screen.
[*]hide the lower status area to maximize use of the small screen.
[*]search for strings in the text of the document.
[*]display PDF files that were sent to you.
[*]send a PDF file to anybody in the world, using E-mail, Infra-Red or Bluetooth. [/list:u]
Rafe wrote:Thanks to mBrainSoftware you can now read PDF files on your Series 60 device. The software enables you to not only open the files, but zoom in and out, follow bookmarks, view in full screen, search files and more. The first public version is a beta.
With Pdf+ you can:
This program works great yet when I used it i had some errors on my programs like xxxprogram closed errors, then every program i opened got errors. I restarted and it works ok but after a couple of clicks im having the same errors. Has anyone encountered this? I suspect pdf+ because its the last program i installed. Hmmm... I even reached the part where the phone will just shut down so I took out the batt and place it back it to boot but it only shows the nokia logo then fades out then shows it again then fades out again. I resolved it by pressing the pencil key to boot. It worked but im worried if this program can corrupt my system and ruin my working setup.
Any one can relate?
