Hi all im havin problems wen i send pic, software to my nokia 7650 from my computer it works fine but for some reason when im tryin to send images back to my computer its sayin UNABLE TO CONNECT can any1 plz help me cheers. :cry:
Bluetooth
Try updating your BT driver,most older versions of BT drivers based on the WIDCOMM stack suffered from that problem.If you don't care to update,try transfering them with PC suite,i think it works.
I had a similar problem, it turned out that i hadn't paired and set my computer to auto-authorise any connections from my fone! Check the settings on the PC!
I have exactly the same problem. PC->3650 Fine ./. 3650->PC Does not work.
I have installed Sitecom BT.
If I want to connect explicitely the phone, an alert box pops up: "The Bluetooth serial port COM0 will be used when connecting (...) Application that use this service must be configured to communicate using COM0. It can be started at any time." and afterwards another alert box: "The remote device closed the connection."
COM0 ??? - I didn't even know this exists.
Anyway, how can the configuration be started?
The installed Widcomm Bluetooth Software Version is 1.2.2.9
Local Services Bluetooth Serial Port is COM5 (but I tried every other possible COM-Port with no effect).
Client Applications Bluetooth Serial Port is COM4 (but I tried every other possible COM-Port with no effect).
Nokia PC Suite is no help at all because it needs the mRouter first to be run, but mRouter is the worst of all: It shows only one possible connection: Infrared. Nothing I can do there.
I appreciate any help.
I had similar problem and was pulling my hair out trying to resolve it. Eventually for some reason I went into the Bluetooth system config setup, chose Accessibilty and selected my N7650 as the only device to connect. Worked for me 😃
Flugel
LFC Online
http://www.lfconline.com
