Netmonitor 4 3650
6 replies · 2,238 views · Started 24 July 2003
Please help me! My netmonitor not work... It running in task and do nothing! What's the problem! THX!!!
What netmonitor is that? (I'm not aware of an application by that name for the 3650.)
So, what application is it, exactly (name of installation file, name of application in the menu hierarchy when installed, name of application when running)? Where did you get it from? What do you expect the application to do? What, exactly, happens when you launch it? Any screenshots to show? Error messages? Does everything else work?
It is as if I had said to you: "My VCR player is stuck (it is). What's the problem?" How on earth, you think, could anyone solve my problem with my VCR with so little information to go by?
In other words, you have given absolutely nothing in terms of actual details on what you are trying to do, what the problem really is, etc.
Mind-reading is not an exact science yet, and doing it through the WWW is even more difficult. 😉
No doubt he means Field Test, which as far as I am aware, does not work on the 3650.
[quote="j2k"]No doubt he means Field Test, which as far as I am aware, does not work on the 3650.[/quote]That's what I thought, too, but I wanted him (her?) to say it. 😉
[quote="N/A"]Mind-reading is not an exact science yet, and doing it through the WWW is even more difficult. 😉[/quote]
There is no need for mind reading, because no Netmonitor (or Field Test) has been published for 7650 or 3650.
If somebody claims they have Field Test, it is obtained illegally, and no-one having this kind of software, can expect any support for it. Not at least from here...
always make sure the programs you using are 3650 compatible coz otherwise you could have ALOT of headache on your case!
