GoBoy and ZipMan question
4 replies · 1,728 views · Started 25 July 2003
well.... just send it to your phone using BT FTP transfers. works well for me.
But.. Zipman should find them whereever they are located. it is the extension, the program looks for as far as I know 😊
If the roms are zipped, like Tatus said ZipMan should locate them as long as they are on the phone because its associated with .zip files.
what i mean is in the zipman menu. when i choose options, add file then GB roms, it tells me "No data". i just want to zip my rom and my saves coz i'm sending it to my friend's phone. anywy, its not relly important. sory if my first question was kinda vague.
you have to zip it on the pc, before sending it to the phone.
I have never used the zipman program itself. install it and when the phone tries to open the file, zipman opens it for you in the background 😊
Anyone add or correct if needed 😉
