hi,
i can't connect my 7650 to my laptop via IR. i have installed mrouter and the pc suite, but when i check the IR port, it says something like "port may be in use by another application". but i can't see any conflict problems so far. i can send and receive files using the infrared receipient, but i can't use the pc suite.
please help!!!!
thanks,
ryan
[quote="ryan"]hi,
please help!!!!
thanks,
ryan[/quote]
Ryan, check if mRouter is set to use INFRARED and not the COM ports
When i try to use the irda, the connection keeps going on and off, and i can't synchronize or send files. The mrouter doesn't work 4 me too. Can anyone help me?
hi there guys!
i just purchased a nokia 7650 and i do not know how to upload images from pc to 7650 and vice versa. i have an infra red device with me. pls help. thanks!
milet jones
Hey guys..
I can't connect my nokia 7650 using IR because it continuously say that 'found new hardware standard modem over IR'
This mean that I can't run and activate pc suite for the first time. Any help on how to disable nokia as a modem ? I dont want my pc to detect my nokia as a 'stupid modem' :cry: :cry: I'm running windows XP Please I really need help on this.
Email me at [email protected]
Thanks.
