New: MovieMaker - optimise videos for playback on P800
2 replies · 3,096 views · Started 25 July 2003
Moviemaker for P800 is a piece of helper software that eases the creation of videos for the P800. It converts video files into a format, size and quality optimised for playback on the P800. Currently supported formats are QuickTime, AVI, DV and MPEG.
Demo and purchase from Handango.
Author Release Details
What does it do?
This software allows you to quickly create movies for playback on the Sony Ericsson P800 smartphone. You can take a movie from your DV-camcorder, from a website or from any other source and convert it into a super small file, which is optimised for playback on the P800 built-in video player. Watch your favorite tv-show on the train or show your home movies to friends. The software can do a two-click conversion of a video file to a P800 movie. It's easy and fast and all settings are done automatically.The software dramatically reduces file sizes, so that a half hour tv-show fits onto a 32 Mb Memorystick. A feature film would fit on a 128 Mb stick.
Most AVI, DV, Quicktime and MPEG formats are supported. Certain movie files can't be converted. For example Real Video and WMV-files are not compatible with this software. Also protected files, such as DVD's are not supported. Other than that, you can pretty convert anything that moves.
What version of Quicktime do I need?
Get Quicktime 6.0 or higher and do a standard installation. You need the free Quicktime Player, which is part of a standard installation. Get the latest version here. Moviemaker does not need the professional version of Quicktime to work.
What are the limitations of the demo version?
The demo will stop working after a minute, allowing you to convert small movies (up to 30 seconds), but not larger files. Also the demo will pop-up a 'Buy Now' window.
Where do I find free movies on the internet?
There are tons of free movies on the internet, which can be downloaded and played on your P800. Check out these websites:
The links can be found if you click the Handango link (it was copied from there, but the links didn't copy/paste that easily 😉 )
So what about DivX? Guess not eh? Or are these treated like normal AVI's?
By the way, price is great, if it works!
