Can the BLB-3 battery used in the Nokia 8855 be used safely and effectlvely in the Nokia 7650?
Read somewhere that the BLB-3 is 1000mAh compared to the BLB-2
I tried to put BLB-3 in N7650, but it is thicker and does not fit in the phone. The battery cover cannot be closed. So stick to the original BLB-2 or use non original batteries( even 1250 mAh).
BR, Miro
I thought the 8855 and 8850 were of the same size, assuming the battery can fit in the 7650. Thanks anyway.
Ejackly i use BLB3 on my n7650 more safety is right, but problem is u must loose the batery cover first. . .
