i have heard of :
Martin Fields Overlay Plus
but i havent seen it anywhere in the uk, does anyone know where i can get it from, online or otherwise? I could order from the USA but i would rather save time and get it from somewhere in the UK. Also the same with a horizontal wallet case.
Cheers
ceanth
i know someone who has bought like 200 of them i think and is selling them including postage and packaging for �9:49, i was meant to send my order through like last week but i kinda ran outta money so i gotta wait for the next pay day, 😮ops:
if you'd his details, email me using the button underneath this writing 😊
I bought the WriteShield from Expansys.co.uk (expensive though) and a Krussell horizontal case (made for the 7650 but ideal for the P800 sans flip) from JAG communications. This case is now 9.99 as they tell me they aren't being made any more. 😞
I think JAG only have shops in the South West.
does the krussell have a magnetic flip? as in the flap and a belt clip rather then something which ur belt has to feed throu it?
The Krusell has a magnetic catch on the front of the case and two belt loops at the back. You can also buy a range of clip-on attachments for it, including a belt-clip. I think the case is actually called the Horizontic Premium or some such.
I should add that the fit is a bit too snug with the phone flip on but fits perfectly with the flip off.
Edit: I spelt Krusell wrong 😮ops:
You can see the case here: http://www.krusell.se/horizontic.asp
Isee they also make one specifically for the P800; I upgraded from a 7650 though and mine fits the P800 fine, apart from the extra holes. 😊
the only hole i would need is the one for the headphones, if its not there then i guess ill have to make a hole or take phone out when i use headset, it seems like a good case.
The phone can be placed so the headphone socket is accessible easily enough.
Enjoy 😊
