nim files??????????????
1 replies · 1,557 views · Started 26 July 2003
does anyone know a decent way of converting avi or jpegs to nims? i,ve tried the multimedia converter but this is shite and wo,nt work properly! 😞 😞
[quote="9210nut"]does anyone know a decent way of converting avi or jpegs to nims? i,ve tried the multimedia converter but this is shite and wo,nt work properly! 😞 😞[/quote]
well then i suggest that u 1st convert those jpegs & avi to a format the MMConverter wud support & understand. I thnk VCDGear wud help. Im not quite sure how i got it or even recall wer i got it but it sure does work sum little wonders on its own.
sory for missin out sum details, its bin quite a blur. Hope i helped... in sum way! 😉
