radio on 3650?
14 replies · 3,678 views · Started 26 July 2003
is there a radio application for the 3650 like the 8310 had??
i think thats the only thing missing for it to be a complete phone!!!
Nope. Well, not for real radio anyway.
The closest you'll get is RealOne or Oplayer for streaming radio.
Cheers
well can someone please make one then???
im sure they could use the symbian coding from the 8310!
and if they do make it call it the "sakaveli radio" since i came up with the idea!
by the way, j2k, will it cost to stream radio via realone?
[quote="sakaveli"]well can someone please make one then???
by the way, j2k, will it cost to stream radio via realone?[/quote]
Again, no - unfortunately the 3650 just doesn't have the required hardware for proper radio transmissions. 😞
Regarding cost - it will be your standard GPRS rate.
Hello?!Where av u been people!Av u heard bout AVEC Radio app 4 36/76.U can listen 2 netradio or any station broadcasting over the net.
Hardly real FM radio though is it? And the quality is less than brilliant for me.
Well you're not the first to ASK... No you can't. 8310 has a FM radio receiver built-in. 3650 does not, simple as that. If you want to stream, then prepare to pay for GPRS. Rates vary from each mobile provider.
@ the end of the day, you'll pay more.. Worth it?.. Not for me.
i always thought that the handsfree was the reciever and thats why radio didnt work at all without the handsfree plugged in!
how wrong i was then!
Only SonyEricsson has their radio has an addon plug. Nokia's is built into their phones. Soon, they'll be releasing the addon. But it'll only work on phone with the pop port plug.. So that means only series 40 color phones. 3650 doesn't have the pop port, so you're suck with none. SE made it, that most of their phone can plug their HPR-20.
Nokia always does some crap to annoy people :P
Btw.. the HDD-1 that comes with 8310 is just a handsfree headset. No radio receiver. It can be used on the 3650. I've tried it b4, but sound still sucks.
[quote="Anonymous"]Hello?!Where av u been people!Av u heard bout AVEC Radio app 4 36/76.U can listen 2 netradio or any station broadcasting over the net.[/quote]
u guys REALLY want to listen to radio over the net on your phone and pay the GPRS charges!?? I would just get a small digital radio that fits into my pocket. Only have to pay for the batteries thereafter. 😉
my thought exactley!
ive had my phone nearly 4 months now and my gprs counters are still blank!
i'll be damned if i get charged some stupic overblown price for data transfer i can do better, quick and cheaper with my pc!!!
the name of the sofftware you search for is:
avec radio
radio player for 7650/3650
mfg gegy
sakaveli wrote:my thought exactley!
Your plan sucks then.... I have unlimited GPRS through T-Mobile for $3.00/mo. I can stay connected to it 24/7 if I want and never incur an additional charge.
PimpOmatic
u living in singapore or other country...??
if u living in spore.. how to regeter for the plan u say...?
PimpOmatic wrote:Your plan sucks then.... I have unlimited GPRS through T-Mobile for $3.00/mo. I can stay connected to it 24/7 if I want and never incur an additional charge.
PimpOmatic
