Ok...i did try using program to make those ringtone louder...It did increase ..but still soft.....
How can I make it rings louder..I hardly hear the ringtone will my phone ring...
or by default 3650 ringtone is soft?
there are certain applications you can download to boost the ringtone volume, unfotunatley i cant rmbr the program name that does it, if it comes back to me i'll let you know!
try ringtone studio
besides ringtone studio, are there any other programs?
and can ringtone studio makes our ringtones louder?
Here's a tip - with Ringtone Studio, you can duplicate the main instrument of that ringtone and set the volume to max. Duplicate more to make the sound louder. Works for me.
Alternately, there's a midi editor called PSMPlayer. It's simple and easy to use. The program's not too big as well so loads easily on your PC.
You've got two choices, each with its own advantage. I usually use Ringtone Studio coz u can take it around with you in your phone. The other is better but you can only edit your ringtones on your pc. 😃
Thanks for that track duplication tip! Just tried it on Sk8er Boi and it's noticeably louder now!
Mid's volume can be changed with PSM Player. For wav's you gotta use some wav editor (Google will find lot of them).
Wavs can be easily edited. Heck, if you're using Windows you can just use the windows' recorder program that comes with it.
Anyway, your welcome. What's Sk8ter boi tho?
Avril Lavigne.
Oh ryte.. tot u were talkin abt some kinda program
Anyone knows where i can download this PSM Player,been searching google and all i can get are some PS2 japanese websites i don't understand 😊
-Edit-
Never mind,found it,works great!
Click on Profiles, Select the profile (Normal or whatever), Click on it again and select Customize, Go down to Vibrating alert and turn it on.
Now, call your Nokia from any other phone and listen to your much louder ringtone.
I really don't think that will do much good,i already have vibrating alert turned on.I recommend PSMPlayer though,it can rally boost the volume of your midi ringtones.
i have psm too..but it dun make much difference.......
i want the tones as loud as 7250 phone....
See if this makes a difference.The psm edited version could've gone even more loud.
i have tried using ringtone studio and it worked.. the midis can really be set double the volume..
You should try PSMPlayer. It helps a lot. But I would recommend Ringtone Studio's duplicate technique. Try a combination of both. Increase it in PSMPlayer then use Ringtone Studio to duplicate it and delete unnecessary intruments. But when ringtones are too loud for the 3650, it just doesnt sound as good.
Gluck
[quote="GhostDog"]Anyone knows where i can download this PSM Player,been searching google and all i can get are some PS2 japanese websites i don't understand 😊
Never mind,found it,works great![/quote]
Click below for direct PSM Player english version download link,
http://www.ne.jp/asahi/phs/phs/psmplayer/psmp380e.zip
Wishes you all the fun and bye! 😃 :angel:
You may also try another alternative: MidiTurner , it is a totally FREE software simply designed for amplifing midi volumes.
The midi really became louder on my nokia 6680 thanks to PSM and ringtone studio and how do you guys turn the ogg file louder? I am using the sound recorder from the windows to turn the wav files louder maybe about 200% then convert it to ogg with normalize sound so is that ok? Does the normalize sound functions revert the ogg volume back to the original loudness? if in that case should i turn it off instead?
