I dropped my P800. It surived the fall from the chest pocket of myshirt, when I jumped over a fence. It landed first on concrete then bounced and ended up on a steel man-hole cover.
I firstly thought that is was bye bye P800, but on closer inspection I've only scratched the case (although quite nastily) and put a few scrapes on the flip (thank god I didn't take the flip off).
My question is, can I get a replacement case and replacement flip??
You running from the law or something istacey? 😃
Cant believe the P800 survived such a fall... thats well lucky.
My P800 screen is damaged due to the stylus scratching it (should have got a screen protector) and I was told by SE to contact Celestica on 01952 230 402. But I think thats if you're in the UK I guess. Havent tried them yet.
Hope this is of some help...
I'm in the UK!
Not on the run, was in a hurry to get ot the pub!
Thats alright then. Pub is very important too!!
Well, as I said you can try that number. Or otherwise I'm sure they will be someone that can make a recommendation for antoher way to get you're phone fixed...
Good luck with it!
