Embeddable application
1 replies · 1,155 views · Started 28 July 2003
using stacker, when i zip up certain apps, i get "embeddable application"
what does this mean?
It means that the applications is associated with certain file type(gb files with GoBoy).Sometimes,compressing embedable apps with Stacker might prevent the app from functioning correctly(If you compress GoBoy,when clicking on a .gb file,it might not work)
