I want to be able to type a text message using my keyboard on my Windows Machine, then press send and either have the phone connected via infrared or bluetooth and it just sends the sms.
any options out there?
Andy 😊
Andy 😊
Indeed! Search for Remote60. You can do THAT and much much more....
Cool, thanks, just looked at that, i was maybe thinking of something freeware, that just did SMS.
I've just installed the trial, seems good.
Is there anything else?
None that I know of...
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=15532
Excellent app which does just that!
Will
I have just recieved a 7650 after having a 6210. I asked the supplier of the phone what i could use to do the sms from pc. They were more than unhelpful. It looked as though I was going to give the phone back, until I was directed to this forum. After having the Remote 60 on my system for about 10 mins I bought the full package. It does more than it says on the box. It is a brilliant peice of software. After converting the exchange rate it cost me �12.30. I had spent 3 weeks looking for something that done this and belive me there is nothing else out there. I would recomend this to anyong who has a 7650. By the way, i do not work for the authors..... 😃
willbrady, thankyou, that is amazing!!!
off to buy i think!!
