Guide to take apart a P800
6 replies · 2,454 views · Started 28 July 2003
Does anyone know where I can see a guide to taking my P800 apart ?
I have a replacement case for my phone but I can get it fully taken apart.
Or can anyone tell me the nearest SE repair centre ?
I could do with getting it unlocked and the software updated
Cheers
Defiant
Not sure of any good guides, but i have taken mine apart, i can give you some help, send pics etc 😃
You will need a Torx bit size 8, and a flat screw driver or hard plastic similar. Getting the jog dial and buttons out will be the hardest part. 😃
[quote="Defiant306"]Does anyone know where I can see a guide to taking my P800 apart ?
Cheers
Defiant[/quote]
I know that I saw a web site containing photos and instuctions of the P800 in various stages of being taken apart; with instructions. I can't quite remember the exact name right now. It was portuguese or spanish and they have all sorts of phones that have been stripped. Abreutmoviles (open mobiles?) or somthing like that. If I find/remember the exact address, I will post it.
Mark.
[quote="Defiant306"]Or can anyone tell me the nearest SE repair centre ?[/quote]It will be somewhat dependent on your location and without knowing that...
Cheers
Defiant[/quote]
I hope this helps.
http://www.p800.it/Tutorial%20video%20montaggio.htm
[quote="sureban"][quote="Defiant306"]Does anyone know where I can see a guide to taking my P800 apart ?
Cheers
Defiant[/quote]
Mark.[/quote]
Here is the website I was talking about: www.abretumovil.com/destripes/sonyericsson/p800/index.html
It's not exactly as I recall it, I hope this helps you.
Mark.
