full charge, thats weird
16 replies · 3,901 views · Started 28 July 2003
i just changed my p800 fully, turned it on and now after about a second its down once notch. Turned it off and pluged in the charger, it went for about a min and then said fully charged. So i put it back on and same problem, is that normal?
when you charge your phone, and it says 100%, it's not really always at 100 percent, that's why when you first get it, are told to charge it for so long, i read this somewhere but can't remember
same thing happened to me today. i fully charged my battery this morning. at around 6:00am it was still 100% it is 2:30pm right now and it is down to 5% 😮
it is really weird. i was not expecting that this will happen because i make sure that i condition my battery at least once a week. i will be having a meeting later this afternoon and i guess i will leave my phone here. it has no use today!! :evil: :evil: :evil:
by the way, i forgot my charger and there's no other way for me to borrow because i am the only one here in the office who is using p800. :roll:
:agrue:
12 quid if your quick 😉
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=3338377209&category=14418
My peice of s**t brick has started doing this also, if I change fully at say 9am, it will be fine until early afternoon say around 2-3pm (80-90% Charge) then it will deteriorate rapidly, so when I go to get my phone at say 6-7pm it will be turned off...when I turn it on, LOW POWER warning (1-5% Charge!)
I'd send it back for a replacement but it's not worth the aggro :roll:
the battery has warranty right? i am planning to go to SE to have this checked. it's not worth it if it's going to happen like this in just a short period of time.
I just accept the faults my P800 has now, I really can't be bothered to get them fixed.
Perhaps when the Samsung arrives then I will get them sorted before I sell it.
I agree with the weird behaviour of the battery.
-Without using my phone i get 2 days of usage.
-When going away and fishing I get about 5 h of usage (using my phone very little, I understan it burns more power when it is far from a antenna).
- When I came back I only get 5hours of usage without hardly using the phone.
- After a few days of limited usage at home I again is back to 2 days of usage.
It must be something is the phone that is triggered to burn power. I just don't know what it is. I have tried just about everything. Finally it goes back to normal burn rate. I just don't know why.
Stefan
yes sony ericsson warranty covers battery and charger too .. i guess everything that comes in the box .. not sure if ear phones are covered too
I am sure that all of you having this charging problems have the beta of the camcoder installed. Camcoder SIMPLY DRAINS THE BATTERY!!!!
Uninstall it and see for yourselfes! 😉
[quote="simply258"]yes sony ericsson warranty covers battery and charger too .. i guess everything that comes in the box .. not sure if ear phones are covered too[/quote]
They are, I got mine replaced, and will replace them again 😃
A battery is normally only covered for 3 months in th UK, after that they put it down to misuse even with no evidence ( :-? ) Leaving any program in the background eats power, i left Gaya on and you could almost see the battery meter go down! That battery on ebay was only 700mah, the p800 one is 1000mah...
[quote="katsj"]I am sure that all of you having this charging problems have the beta of the camcoder installed. Camcoder SIMPLY DRAINS THE BATTERY!!!!
Uninstall it and see for yourselfes! 😉[/quote]
i agree with you katsj. i finally reailized that after installing camcorder that happened to me. :agrue:
Only if you keep the app running in the background! If you close the app when you're done, there is no problem!
