How do I get songs to play?
7 replies · 2,608 views · Started 28 July 2003
I have a song thats in my inbox and I was wondering how do I get it to load in the mp3ngo program im new to this so i know nothing about it
I'd suggest you to use PC suite, which can be downloaded from Nokia.
That lets you send it to a specific folder on your MMC card preferably.
I have them on e:\mp3. You should be able to browse there with Mp3Go. 😊
You may transfer the song using File managers like FExplorer to the mp3 folder made when you installed mp3go. Just cut and paste.
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=15611&highlight=mp3go+headset it is discussed before take a search next time
Ok. Enough is enough..
YES. We do have a search option.. BUT...
Do we have to tell everybody off, for not having searched the forum? We were actually two who had tried to be helpfull before you came in and took the time to find the link.
Why the need to "tell" people to use the seach option, all the time?
Giving the link and politely telling that there is a search option and loads of good info can be found that way would do the trick. This is not about telling people off all the time. I have been browsing around and constantly I see you (Lars) telling people to "use the search option"..
Come on. Give people a break here.. Lets get some of the politeness back please.
And this is not to start a huge argument .. Just think about it. We are all newcomers at some point 😊
Or,you can buy a PC FileManager from www.epocware.com but if the 3650 version of PC Suite has a similar feature then you don't actually need it 😊
his mp3's lands in inbox you can use forward it's a app that allows you to copy your files in your inbox to a folder like E:\mp3 you can download it from this site
