CodeWarrior & UIQ SDK-P800
1 replies · 1,281 views · Started 30 July 2003
Is that true CodeWarrior is only required for emulator not for the target device? Can I compile the app using VC6 instead of CW?
In all cases compiling for the target devices is done using GCC.
You need CW, if you want to compile for and debug using the emulator, when using a P800.
With Series 60 -based phones you can also use MS Visual C++ 6 or Borland C++ Builder.
