I downloaded some games that are jar files but i dont know how to install them unlike .sis files where i can just send it to my phone or double click it
how do i install .jar files
Send them to your phone using BT or infrared.. Then go to your inbox and open the message. It will prompt you, asking if it should install the program.. You may delete the message containing the file, in inbox after installing it 😊
