P800 needs injection of firmware every 3 mths??
6 replies · 2,242 views · Started 31 July 2003
ola guys,
this may seem silly,i know..that there is a latest firmware(R1F) rite?,anyway ive notice that after doing each upgrade (from R1B-R1D)of firmware usually after 3-4mths,they will be new problems or old problems occuring,last updates to R2D was 30/4/03..and upon reaching the final week of july03..problems start to arise...(yellow ex!,screen froze when answering call,etc....) :roll: (or is it just me having this problem? :-? )
anyway we'r all here to improve things and not condemn S.E, just want to share my thoughts and experiences...
for your guys info..i have not upgrade to R1F yet...Should i upgrade? :roll[/quote]
If you have R2D allready, there isn't much sense in upgrading to R2F. There aren't much changes. If you're still on R1D, you should definately upgrade!
when i go to the apps menu, then go to system info tab, then the last one the tag info is missing, it doesn't affect my phone in any way, but if i do a master reset, will i get the file back which says this information? or if i got a firmware upgrade will it give me this info back?
cheers
NK8
U will get it back after a firmware upgrade or u could ask someone to mail u the cda_version.txt file someone said a while back that works to
but it wont comeback after a reset
greetz
