hi folks,
i don't know what happened to my phone. When i got it out of my pocket it was off although it was more than half full. When i turned (and now turn) it on...i see the nokia icon...then it disappears, it appears again, disappears, appears again and so on....
what's wrong with my phone ? anyone had the same problem ?? i guess i have firmware 2.5 on it..
Have you tried booting it without MMC and SIM? That's the first thing you wanna try, if that's not working you can try to boot in 'safe mode' by keeping ABC aka. Pencil button down while phone is booting up. If none of these helps, take it to repair.
Hey dude, you need to bring your phone to your nearest Nokia Service Center.
They will reset the entire ROM. You might have tons of programs installed on your memory. 😃
I also encountered the same problem. As long as your phone is still under warranty, they will fix it without any additional charges.
A warning though, this may take 2-3 weeks. 😮
