is it possible to make an ssl connection in java and which tool should i use ...
thanks ...
vandoor
thanks ...
vandoor
I will very much depend on which device & Java variant we're talking about. Care to elaborate?
in fact i want use my code on a pocketpc and a p800.
i don't know if it will be good, but i try!
On the P800 you have its MIDP 1.0 or PersonalJava (pJava) as options.
On the PocketPC it'll depend on whose Java implementation (Insignia or whatever) you have installed on it as Microsoft isn't shipping one as part of the OS (and I don't think many/any PocketPC hardware manufacturers are adding Java either).
See the respective Java SDK's (Software Development Kits) for what can and cannot be done.
