Hi
When I connected my 3650 to my PC via my TDK Bluetooth dongle I used to be able to then disconnect it by "right" clicking the Bluetooth icon in the system tray and disconnecting it.
But now when I connect my 3650 to my pc it won�t let me disconnect....and I have to re-start my computer.
Any ideas?
Can you not just turn bluetooth off from the phone itself? Then the PC should notice that the 3650 has terminated the connection, and disconnect itself.
no - for some reason the PC does not detect and i have to ctrl-alt-delete....its very odd
What I do is have a shortcut to the BTTray.exe app in my Quick launch bar.
Open Windows task manager. End the BTTray.exe app in process..
Then the BT connection should be history.
Wanna have BT connection again? Click the Shortcut and viola.. a working bluetooth icon should be shown again. Hope this helps
