I have downloaded the SDK that comes as 6 zip files.
Whenever I extract the first zip file, it gives me a message "Error :Invalid compressed data to inflate".
I am using Windows 2000 Professional machine.
I have installed winZip8.1 on my machine.
I tried downloading the complete SDK again.
I have downloaded the Missing files also.
Please help.
I want to use Personal Java as a development platform and develop applications on Sony Ericsson P800.
Thanks for the help in advance,
Shubhangi.
I think you need WinZip 8.1 SR-1 (Service Release 1).
They should've really used a more "generic" ZIP version to compress the SDK.
I am using WinZip8.1 SR 1 only.
But still facing the same problem at the time of extracting files.
Please help.
I am using WinZip 8.1 SR-1 Evaluation version.
Is that the problem? Should I be using Registered version of WinZip?
Pls suggest.
Worked for me (registered WinZip 8.1 SR-1) when I did it a couple of months ago.
See also this.
If it doesn't help, ask about your problem there.
Thanks for the timely help.
I have been able to install and start development using P800 personal java.
Thanks a lot,
Shubhangi.
